Machine Vision
wrong camera resolution reported
I have a RS170 camera/Standard NTSC pattern generator connected to a PCI-1410 frame grabber.
Images are grabbed correctly from within MAX.
By software, when getting the settings, instead of getting 640x480, I'm getting 2047 x 2047.
Any ideas?
Thanks in advance.
JP
(4,020 Views)
Hello physicien nocturne,
Could you tell me what your settings are in MAX? What is the maximum image size that you have set? What other software are you using to grab images from your camera? If it is LabVIEW, what version?
I would appreciate it if you could answer these questions and provide any other details on your issue.
Vivek Nath
Machine Vision
(4,000 Views)
My settings were 640x480 1X 10-bit image
The 10 bits settings in MAX was indeed affecting the acquisition. I putted it back to 8-bit and now my application works.
Acquisition window:
Left:107   Width:640
Top: 17   Height: 480
Bit dept: 10 bits
Field/Frame
Mode: Frame, interlaced
1st field: odd
This, with the other reply to my previous post helped solve the problems.
Many thanks,
JP
Message Edité par physicien nocturne le 04-11-2008 09:46 AM
(3,988 Views)
