Measure
3 wire instrument - need help wiring
Currently using mediamate transducer - link
http://www.intertechnology.com/Honeywell_Data_Inst/pdfs/MediaMate.pdf
Ni 6023e card - using channel 6 and differential
Supply V+  pin 8
Excitation V+ pin 25
Supply V- pin 9
Excitation V-  pin 58
trying to wire Ashcroft G2 three wire transducer - link
http://www.ashcroft.com/products/pressure_transducers_transmitters/high/upload/I-M011-10129-3_05-G2-...
thanks   James
(7,805 Views)
James,
What have you tried?  What problems have you encountered?  Is there any specific questions we can answer?  Just in case your problem is not being able to find a pinout for the 6023e you can find it here on page 12/14.
Sincerely,
Jason Daming
http://www.ni.com/support
(7,798 Views)
Hi Jason,
Please find attachment that may be of assistance.
We are using all of the channels available in differential, channel six is used for this
application.
thanks
James
(7,794 Views)
James,
I cannot answer any of your questions about the other device.  In regards to the unstable readings what exactly do you mean by unstable.  Have you seen this document on unexpected voltages and other things you can do to improve your signal.
Sincerely,
Jason Daming
(7,784 Views)
