Measure
Connect Encoder through RJ50 NI9949
Hi NI community,
I have a Hengstler Encoder for rpm measurements. I'm trying to connect this encoder to NI9237 DAQ using NI 9949 unit. The encoder has four signal wires (Ch.A: white; Ch.B: green; Ch.N: yellow & Alarm: black and yellow).
Considering that RJ50 cables have (SC, AI+-, EX+-, RS+-, T+-), I am a bit lost between their relations.
How are these channels related, since their labelling are quite different?
Thanks for any help.
(4,694 Views)
Hi DNlboro,
I would like to understand why you are connecting an encoder to the NI 9237, which is designed for analogue strain measurements.
Here is a guide that can help you to set up the right hardware to acquire digital encoder measurements:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1riCAA&l=en-US
Let me know if this helps!
(4,657 Views)
