Measure
DAS 4020/12 trigger
Hi everybody,
I'm actually working on labview, programming an acquistion card "DAS 4020/12 trigger". It's an acquisition card with 4 channel+1 trigger
All works good onely my trigger which want to absolutle trig on the chanel n°0. (so i have 3aquisition chanel +1acquistion&trigger instead of 4 acquistion +1trgger)
To prgram it, i use labview+universal library...
I give you thanks for all help you could give me
awawa
(7,857 Views)
Accepted by topic author awawa
You have posted to the wrong board. This board is for an add-on to Excel called Measure. I would suggest you post to the LabVIEW board.
You might also want to attach whatever code you have already written along with a bit more explanation of the exact nature of your problem.
(7,856 Views)
