Measure
Delete Noise (Filter)
Hi @ all,
have on my signal from the pressure sensor a horrible noise factor (it is amplified). I´m really sure that the effect comes from the ambient power wires (lights, PC etc...)
It is 50Hz.
I tried to decimate it with a filter. It works fine... but i am not sure if i had done the right thing. The signal is read with a speed higher than 100Hz to 1.8kHz.
I attached my result and which filter i´m using.
I would be glad if anybody can give me a statement about it.
Cheers
(7,913 Views)
Here the Attachments...
(7,912 Views)
Since Measure is an old add-on program for Excel, you should post to a more appropriate board.
(7,901 Views)
Hi Sirit,
As your signal is amplified, you need to be able to take the low frequency (and low amplitude) signals and reject the higher frequency signals. You need a low-pass filter for this purpose--the Chebyshev filter is a lowpass filter and actually has smaller absolute errors. Your cutoff signal looks fine to me.
Ipshita C.
(7,885 Views)
