Measure
ECU Measurement​t and calibration​n API support for Win64 programming
I use ECUMC tool kit to using the C APIs provided by the niemcc.lib. But as for my understanding goes this is Win32 APIs and would work only on 32 bit windows.
Is there a support for Win64 API as well?
(6,753 Views)
Hello arunhsc,
Thanks for posting in the Discussion Forums! As the white paper National Instruments Minimum Version Requirements for Microsoft Windows 7 show, the NI ECU Measurement and Calibration Toolkit 2.1.2 is supported on Windows 7 64-bit only when using 32-bit software. So as far as the OS goes, there should be no problem as long as you don’t use it for 64-bit applications. I hope this helps!
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
(6,739 Views)
Hi Daniel,
Thanks for the reply, this helped. I am actually trying to use it in a 64 bit application but I think that would not be possible currently.
I am hoping there would be support for it in the future releases.
Arun
(6,734 Views)
