Measure
Environmental sensors that can be used with the NI sb RIO-9631(humidity,light)?
hey all,
i am a new research student and have just finished the startup and interfacing of the NI sb rio-9631. For certain applications that i intend to work on, i wanted to know of some environmental sensors (humidity, light) that can be used with this platform. Thanks
Regards
baig
(5,988 Views)
For integrating sensors, you'll want to use the analog inputs on the 9631. While I can't recommend any specific manufacturers or sensors, your best bet will be any transducer with a voltage output, as that will be easiest to read with the NI Single-Board RIO analog inputs.
Caleb Harris
National Instruments | http://www.ni.com/support
(5,980 Views)
