Measure
FP-TC-120
I'll try to calibrate with Calibration Executive a FP-TC-120. The CJC test is failing. The measured temperature next to the module is very close to the number reported by the software but the Calibration executive evaluate around 30C. There is no independent temperature measurement asked by the Calibration Executive.
Can somebody explain what is the relation of the CJC and the 30 C?
(5,919 Views)
tfulop,
Which Calibration Executive version are you using? Could you post the CJC error?
(5,908 Views)
