Measure
How do I load the TED files from the EPROM of a Tranducer technique load sensor to CDAQ-9237
(6,902 Views)
Hello Polymer123,
There are a few different ways you can access the TEDS data on your transducer.  Assuming that your transducer meets the Sensor Templates then you can access your TEDS from Measurement and Automation Explorer (MAX).  After have installed the 9237 on your machine and attached the TEDS sensor to it, open MAX and click on Devices and Interfaces to expand the list of DAQmx devices installed on your computer.  Right click on your 9237 and select Configure TEDS.  You can then select the channel you have your sensor attached to and click Scan for Hardware TEDS.  This will configure that channel for the TEDS device installed to it.  You can then use the DAQ Assistant or the DAQmx Create Channel VI (configured for a TEDS task that supports your transducer) to read from that particular transducer.  If you plan on changing the TEDS device often you can also read the TEDS information programmatically.  Let me know if you have any more questions.
Browning G
FlexRIO R&D
(6,885 Views)
