Measure
How do you read temperature into labview and convert to a pressure value
Im new to labview I m trying to design a project that reads in temperature into labview through a themistor and then convert that temperature to its pressure equalivent I have the first part done. reading in the temp values works but how do i convert it to the pressure. I know what the pressure values should be is there a simple way i could use the temp values and compare them to the pressure values and display them on a gauge. By the way i didnt want to write entire new program to read pressure because i think it will get to complicate for my first project
(5,972 Views)
Is there an equation you use to convert temperature to pressure, or are you comparing values with some kind of look-up table?  How is this conversion being done?
(5,970 Views)
