Measure
How to determine measurement accuracy required by a source.
I have a DUT that has a certain accuracy specification and I want to make a measurement to see if the device meets the accuracy specification.
So I will input a signal from a calibrated source to the device.
The question is, what is the minimum accuracy specification required for the calibrated source?  I assume the minimum accuracy would be expressed in terms of the specified accuracy of the DUT.  This is important because the accuracy of analog output boards is different, and I need to choose a board with the correct accuracy for my test.
Someone once told me that there is a Six-Sigma Black Belt rule of thumb that the source or measurement device should have an accuracy that has at least 3 times the accuracy of the input being excited or the output being measured, but I have not been able to confirm this.
Any help would be much appreciated.
Thanks.
(6,361 Views)
This is the wrong board for your question. Measure is an obsolete product from NI and this board is not a generic dumping place for questions.
(6,355 Views)
