Measure
How to get several counter and volt signals to same que.
I can't find any good examples for how to measure several counters from one 6602 card in parallel. and secondly I would appriciate if there existed an example showing how to send these counter values to the same que as another parallel measurement from a SCXI-chassis. (with the correct time stamps)
(6,875 Views)
Are you actually using the program called 'Measure' (an add-on for Excel)? If not, you posted to the incorrect board. Select the appropriate programming language board or the Multifunction DAQ board and provide the language that you are using.
(6,863 Views)
This issue has been solved by the NI support Swe
/Christine Nilsson
AE SWE
(6,815 Views)
