Measure
How to use an analog signal to conditionally generate a TTL(or square function) signal?
Hi everyone,
I am using PCI-6229 and trying to develop a code that can generate a TTL/square function signal as soon as one analog input satisfies following conditions: 1. Crossing a certain value (say, 0 V); 2. Falling edge slope. The time delay between the crossing point and newly generated TTL/square signal will be critical in my measurement, and it should not exceed 1 millisecond. Any suggestion on it? Thank you in advance!
(7,051 Views)
Accepted by topic author Matt11
Are you actually using the Excel add-on called Measure? That is what this board is for. Otherwise, you should post to the Multifunction DAQ board and mention the language that you are using.
(7,050 Views)
Thank you, Dennis. I think you are right, and I should have posted it on DAQ board. Thanks again!
(7,043 Views)
