Measure
I'm using a RMS statisticas block and I have problem with it when I'm working in high frequency. Somebody can help me?
I'm using a RMS statisticas block and I have problem with it when I'm working in high frequency. Somebody can help me? The block has some limitation condition?
(6,779 Views)
I assume by "block" you are referring to a LabVIEW Express VI. You should probably post your question (and consider clarifying this point) in the "LabVIEW General" category. The "Measure" category is for questions pertaining to the Microsoft Excel DAQ/GPIB/Serial add-in called "Measure".
Good luck,
-D
(6,779 Views)
