Measure
Is there any incompatibility between Labview 8.5 and Traditional DAQ?
Hi,  I`m using a DAQPad 6020E and the Labview 8.5 Daq assistant don`t detecte my DAQ when a try to create a new task (to create a new virtual chanel). But MAX detect the DaqPad. So, is ther any incompatibility between Labview 8.5 and traditional Daq? Do you know how can I resolve this?
Thanks.
(6,199 Views)
First, you posted to the wrong board. Measure is an old add-on for Excel.
Second, there is no incompatibility between LabVIEW 8.5 and tradtional DAQ. There is an incompatibility between traditional DAQ and DAQmx which is what the DAQ Assistant uses. Make sure that you install DAQmx if your device is supported by it. Otherwise, you will not be able to use the DAQ Assistant.
(6,194 Views)
