Measure
MAX unloading without warning
MAX unloads from system and crashes LabVIEW.
 System1: WIN7, LabVIEW 2019, MAX 19.5
 System2: WIN10,Labview 2019, MAX 20.5
No MAX error is given Labview errors out on equipment error and MAX can no longer be loaded. Its like MAX unloads from memory. If you start MAX the green screen shows up then goes away no longer able to load. Rebooting system corrects the issue however it just returns. System will run for awhile seems to be at random. Anti virus runs once a day but system crashes anytime. Once MAX crashes Labview will open and I can run VI's as long as I don't access any equipment. Once equipment VI is added to back panel and localhost is selected Labview will stop responding even before running and remove itself from memory no error.
Message 1 of 1
(3,090 Views)
