Measure
Measure Add-in won't install in Excel 2010
I've used Measure 2.0 on other computers successfully, including one running Excel 2007 with the VBA converter pack.  However, I cannot seem to add it to Excel 2010.  It is listed and selected in the Active Add in list, however it does not show up in the Add-ins menu with my other add-ins.  Any suggestions?
thanks
(7,879 Views)
Hi Jessica,
I am sorry to tell you that unfortunately, the Measure product reached it's End of Life date back in 2009, prior to Excel 2010.
Nathan S.
(7,865 Views)
That's too bad it reached its EOL.  Fortunately, it does still work in Excel 2010, you just need to install the VBA converter hotfix correctly:
http://support.microsoft.com/kb/926430
Once unzipped there is a readme file that specifies which files you need to move.  Turns out I had just forgotten to move one of the files.  Once all the files are moved and the VBA modules are migrated, then Measure still works great in Excel 2010
(7,860 Views)
Hi JessicaM,
Im facing a similar issue now as well. How did you get the gpib and serial xla files migrated?
thanks
(7,745 Views)
We only had to migrate the VBA code, not the actual serial or gpib tasks that you set up within the add-in.  To migrate the code, you just export and delete each module, then import it back it
(7,742 Views)
Thanks JessicaM. Invaluable info. Worked a treat. all PC's now upgraded and OK. Sorry for the (massive) delay in replying. Rarely log in.
(7,030 Views)
