Measure
Measure v 2.0 on Windows 7 x64?
Hi all-
I am trying to install Measure version 2.0 onto a Windows 7, 64-bit machine. Is this possible?
Most 32-bit applications are capable of running in a 64 bit environment. Is this not the case with Measure?
I know the version I have on disk media is an old one, is it possible to acquire a 64bit capable version of Measure 2.0?
Thanks.
(6,739 Views)
I think this would be possible although I have not tried it myself and officially it is not supported on Windows 7 according to the user manual (which was probably written long ago). If you get this working it would be good to record your findings here.
User manual for Measure 2.0:
https://www.ni.com/pdf/products/us/3msw128-129.pdf
(6,726 Views)
I forgot to mention that I did try to install, it did not work.
I cannot recall the actual error message but it was related to file system architecture.
(6,723 Views)
OK that most likely means that this will not be possible on a Windows 7 computer. I'm sorry that does not seem to be a viable option at this time.
(6,710 Views)
