Measure
Minimizing parasitic capacitance in set-up
I'm running an experiment with a MEMS variable capacitor device. I want to minimize the parasitic capacitance of the electrical connections and wires. What kind of wires should I make my connections with? Stranded wires, solid wires, coax cables? My devices have 50pF or less capacitance, so my measurements will be off if there is a lot of stray capacitance from the set-up.
(6,967 Views)
Hello John,
Is your variable capacitor differential or not?
Regards
Frank R.
(6,954 Views)
When I'm characterizing the capacitor, one end of the capacitor is to ground. When I'm using the variable capacitor in other set-ups, it's differential.
(6,951 Views)
Hi john, sorry for aask you again before give an answer but, I would like to know first what kind of "MEMS variable capacitor device" you have, do you have a model number or its name?
Regards
Frank R.
(6,940 Views)
It's made from a series of interdigitated electrodes fabricated on doped silicon. I fabricate them myself in a clean room as part of my grad school research. After fabricating the devices, I mount them with epoxy to a custom made PCB. I use gold wire bonds to make electrical connections from the MEMS to the PCB.
I have the option of using coax connections to the PCB because I have SMA edge connectors. I could also just solder a male pin head, and connect wires that way. I don't have pictures now, but if it is unclear what I an saying, I could provide some.
Thanks for the help,
John
(6,937 Views)
John,
The truth is that I do not see a big difference between these options if you are talking about parasitic capacitance. This cable is going to be part of your connection to a different device, this is not part of your PCB (where it is a big deal), so I really do not see a difference. However if you have the option of using coax connections to the PCB, go ahead.
Regards
Frank R.
(6,877 Views)
