Measure
Pressure sensor failing to provide reading.
Hi all,
I'm using an RS comoponents pressure transducer UK part number is 461-323 http://uk.rs-online.com/web/search/searchBrowseAction.html?method=searchProducts&searchTerm=461-323 trouble is I can't seem to get anything from it.
The obvious things like the wiring and the voltage set-up appear to be correct and in signal express I'm seeing some noise coming through, however, when I apply a presure to the system, I get no change in the reading. It is as though the system can see the sensor, but not get a real reading from it.
Anyone come across this kind of thing before or any suggestions as to what may be going wrong?
(5,594 Views)
Hi docb
How are you trying to get this sensor information into your computer?
What National Instruments hardware are you using?
Which drivers do you have installed?
Have you been able to measure a change with any other hardware such as a multimeter?
Regards
Robert
National Instruments UK & Ireland
(5,580 Views)
