Measure
Remove channel from DAQmx AI task - reconfigure existing task
Is there still no way to remove an AI channel from an existing DAQmx task? I know that it's possible to add a channel to a task using DAQmxCreateAIVoltageChan.
Removing seems to be possible only by clearing the task and creating a new one, but this ends up in error -50103 (The Specified Resource is Reserved.) at creating and clearing a task continuously (after ~ 100 - 1000 iterations).
Measuring device is USB-6225.
Any idea ?
(5,881 Views)
Unless you want to learn how to do this with the Excel add-on called Measure, you should post to the much more appropriate Multfunction DAQ board.
(5,875 Views)
