Measure
Requirement Gateway
1) I am able to display requirements with "Result" attribute and value is "FAIL" using the attributes condition
(attr2.typeName = "Result" AND attr2.ident = "FAIL")
2) also able to count using code OTscript  STR($CNT(doc5.requirements.attributes[ident = "FAIL"]))
3) I am able to display references for the step 1 mentioned above.
4) I would like to count the references.
Here i have tried using the code OTscript as STR($CNT(doc5.references)) It is not working.
what is the change i have to do in the step 2 to count the references.
Please see the attached image for more details.
Your quick reply is appreciated.
(7,242 Views)
Kals,
Although the document has a references field, it usually does not contain any references.  Usually references are under a requirement.  I figured this out by looking at the Library Report called Upstream Impact Analysis.
I think the code you want is
STR($CNT(doc1.requirements.references))
This will count the number of references of the requirements in the document.  I wasn't able to tell from your post what condition you wanted on this, but you should be able to modify it to your needs.
Josh W.
Certified TestStand Architect
Formerly blue
(7,223 Views)
