Measure
Requirement gateway report
    In the Requirement gateway i have given the requirements document. So the tool management view shows all the header information from the input word file. Please see the attached image file.
I would like to extract the header information shown on the management view in to the text file.
Is it possible? then how to do that.
i am trying to capture the text  as below in the automated way of generating from the Requirement gateway.
Sample text file content from the attached image is
1.0 Tire Pressure Monitor System (TPMS) Telltale
1.1 Functional Description
Table 1.1  Tire_Press_Telltale Signal
(7,756 Views)
    Please reply ASAP. It helps to solve the above mentioned issue immediatly.
Thanks in advance
Kalyan
(7,740 Views)
I'm not sure what the correct forum is for the requirements gateway but I doubt that it is this one. Measure is an old product from NI. It's an add-on for Excel that allows you intergrate DAQ into a spreadsheet. Because it is an old product, it does not see a lot of traffic and your post is probably just not being read. I only happened to read because I was curious as to who was still using Measure.
edit - just noticed that you've done several posts to this board and have gotten answers. Just have some patience.
Message Edited by Dennis Knutson on 10-18-2008 09:17 AM
(7,724 Views)
Kals,
All you have to do is get the document that you would like to write the sections of, and then loop over the "Section/Entities/Requirements" of that document.  One you have those elements, put a paragraph section into the loop and simply drop the display of that element into your report.  See attached screenshot for example.
Message Edited by Josh W. on 10-31-2008 04:22 PM
Message Edited by Josh W. on 10-31-2008 04:24 PM
Josh W.
Certified TestStand Architect
Formerly blue
(7,665 Views)
