Measure
Slow measurement
Help me.
Connect two CompactDaq to one PC,
I'm creating a device to measure with each module.
Please check the reference picture.
When such measurement is performed, the operation becomes abnormally heavy.
Although the sampling time is 100ms, it takes about 1~1.7 seconds to make one loop.
In addition, it does not consume much PC resources (CPU and memory).
Do you know the cause?
Is LabVIEW speed like this?
(4,732 Views)
Hello John,
Google "Learn 10 functions in NI-DAQmx and handle 80 percent of your data acquisition applications"
Once you go trought the document, you should get a better understanding of what you need to achieve your readings.
And if you're still having problems, please attach the actual .vi, not a picture.
Saludos.
(4,007 Views)
