Measure
Strain gage
Good morning .
I am making a study to measure elongation in bars of a lattice. I am interested in use strain gages. This options make me afraid of, because the lattice has a great vibrations. Will the measure of elongation be affected by the vibrations?
Thank you.
(4,465 Views)
Hi AbelCoyan,
yes, it will. You can gather further information from the following links:
The use of strain gauges in vibration-based damage detection
http://iopscience.iop.org/article/10.1088/1742-6596/628/1/012119/pdf
When using strain gauges to measure vibration of a beam, what is typical signal to noise ratio?
https://www.researchgate.net/post/When_using_strain_gauges_to_measure_vibration_of_a_beam_what_is_ty...
Hope it helps!
Jesús
(4,389 Views)
