Measure
Sweep output voltage from 0V to 20V E3631A
Hi Everyone,
I’m a new LabView user and my LabView 2013 level is quite low and I’m looking for help. I created some simple software to control my power supply Agilent E3631A. So far I can set up output voltage for all 3 channels and monitoring voltage and current as well.
I want to sweep output voltage from 0V to 20V, using for example 20 points and obtain the current both in a graph and in a table. I spent a few hours analyzing various examples but I could not imagine anything.
Thanks for your time and effort
Artur
(3,865 Views)
You need to supply all the SubVI's of your LabVIEW code, if not, one is not able to run and test what you are doing.
Pamela Gómez
Applications Engineering
www.ni.com/support
(3,832 Views)
