Measure
Trying to get Measure to work with PCI 6221
Folks -
I havew Measure 2.0 and a PCI 6221 DAQ card.  The measurment and automation explorer tells me th card is working just fine.  I tried to set it up in Measure 2.0 but I keep getting an error10401 which sdays that the driver does not sup[port the device or has not yet been configured using NIDAQ Configuration utiulity.
Can anybody help please???
tchofelich@dow.com
(6,808 Views)
Measure can only be used with the Traditional (Legacy) NI-DAQ hardware driver.  Your device, the PCI-6221 M Series DAQ device, can only be programmed with the NI-DAQmx hardware driver.  So, unfortunately, your hardware and software are not compatible.  Have you considered LabVIEW?  Seamless integration of NI hardware and software, not to mention hundreds of experienced LabVIEW users on these forums 🙂
-Alan A.
(6,801 Views)
