Measure
Using a 9221 cDAQ module in a 9171 with Lab View 8.5
I would like to measure 2 dc voltages using the 9221 module in a 9171 cDAQ.  I have LabView 8.5 and a few other NI programs.  I cannot figure out how to make the instrument show up in the block diagram to access the channel data.  The online tutorials are for the latest version of LabView and the DAQ assistant doesn't seem to be one of the options in version 8.5.  Can someone provide the steps to accessing the voltages?
(6,724 Views)
You have posted to the wrong board. Measure is an obsolete product - an add-on for Excel.
The DAQ Assistant is most certainly an option for 8.5. When you repost, provide the version of DAQmx that you installed. You also need to install it after LabVIEW.
(6,718 Views)
Thanks.
(6,713 Views)
