Measure
What is the criteria used to decide which type of thermal measurement to use? Thermocouples or RTDs?
When the temperature range of the process fits into both or either type of device's capability, are there factors that help determine which device would work better?
(6,981 Views)
RTDs are generally more accurate, more stable, and more expensive than thermocouples. RTDs usually have a smaller measurement range than thermocouples, however you've stated that both are sufficient in this respect. RTDs may be subject to problems with self heating, depending on the thermal conductivity of the media you are measuring. If the RTD is measuring a still gas, self heating can be a problem. If it's situated in a rapidly flowing liquid or mounted to couductive solid surface, this should not be an issue.
Brent R.
(6,981 Views)
