Measure
Why my computer reboot itself when I minimize MAX?
I am using MAX 3 and IMAQ PCI 1408 to capture photo off a microscope. Why is my computer reboot itself when I minimize MAX?
(8,133 Views)
Hi Yan,
Thanks for using our discussion forums. This sounds to me like MAX has been corrupted. I would suggest uninstalling MAX and the IMAQ driver and then installing IMAQ 3.0.1 from here:
http://digital.ni.com/softlib.nsf/954feaeea92d90918625674b00658b83/8e957f73e5b7c47086256f4d0058c162?OpenDocument
This should take care of the problem. However, if you still have any troubles, please let us know.
Regards
Dan Q
(8,124 Views)
I uninstalled and reinstall MAX and NI IMAQ; however, the computer still reboot itself when I minimize MAX.
(8,115 Views)
Yan,
This is a very strange behavior. Do any other applications cause this same behavior on your computer? What about if you tried it on a different computer? You may need to consider cleaning all NI software out of your registry or reformatting your computer as it sounds like something is corrupted.
Regards
Dan Q
National Insruments
(8,111 Views)
