Measure
drivers for Agilent E3634A
Because of some reason, we have to change our power supply from H P 6674A
into Agilent E3634A.
but I can not find the driver anywhere for the Labview 6.0.
What can I do?
(8,490 Views)
Unfortunately, the Instrument Driver Network only has a driver for this device in LabVIEW versions 7.0 and later. You can request this driver through www.ni.com/idnet, or use the Write and Read functions to create your own programs that will perform the functions you need. Best of luck with your application!
John M
(8,486 Views)
Also, You can use Agilent IVI-COM driver with NI LabView (ActiveX) it seems very easy, below is a link
http://adn.tm.agilent.com/index.cgi?CONTENT_ID=1382
"Only a life lived in the service to others is worth living..." - Albert Einstein
(8,435 Views)
