Measure
measure like the testpanel of the USB-6008
I want to measure like the testpanel of the USB-6008. What is the right example of the nidaq installation or what are the necessary c-functions?
The most c-examples quits with an error. So I don`t no what is the right. I searched in the dictionary  "Analog In".
Thx  Pellaeon
(7,663 Views)
you can find all examples for DAQ in C:\Programme\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Analog In\Measure Voltage.
Do not forget adding the include file and the library file to your project. That is described under NI-DAQmx C Reference Help. You can find this under Start->Programs->National Instruments->NI-DAQ-> NI-DAQmx C Reference Help and there under Getting Started--> ANSI C
USB-6008 is supported in NI-DAQmx 7.5 or NI-DAQmx Base. http://digital.ni.com/public.nsf/websearch/4D915A820A76823C862570390075EBF5?OpenDocument
regards
Peter K.
(7,654 Views)
I testet the sampe source code, but the most programms failed. I searched with the debugger and detected, that trigger functions failed on my system. When I comment out this functions, the program works, but I have the output "Acquired 1000" the whole time.
Is there anyone who have a short sample code to read the current voltage of the USB-6008?
regards Pellaeon
(7,601 Views)
