Measure
niScope ReadMeasurement isnt working
Hello, my name is Niki,
i have a problem with my niscope-card. i'm currently developing a program in VisualC, which reads the maximum Voltage from a signal. We use a NI5112 card, and my program stops at niScope_ReadMesurement with the error BFFA4017, and it sayz "Illegal relativeto parameter", what should i do now?? where could the error be?
Best regards, Niki Lauda
(6,937 Views)
Niki,
can you please provide some infos on the driver version you are using and an extract of the code which creates the error? the extract have to contain infos on the software-setup of the hardware.
Norbert B.
Norbert
Expert: Geometry
(6,817 Views)
