Measure
not able to configure DaqPad 6020E
i have a problem with configurating a DaqPad 6020E.
I want to chance the DaqPad channels  from differential do single-ended mode. I can change the options in MAX. But if i close MAX and start the programm again, all settings were set back to standard configuration. If i change other settings,there are the same problems too.MAX does not save configurations.
I installed the Daq 7.5 Driver on Win 7 32-bit.
hope someone can help me
greetings
Alex
(6,601 Views)
You have posted to the wrong board. This is for an obsolete product called Measure - an add-on for Excel.
I would suggest installing a version of DAQmx that is actually supported on Windows 7. You will have to also find a version supported with whatever application development you are using (and have not specified) unless it really is Measure.
(6,593 Views)
