Measure
"NI Device Loader" isn't starting automatically
as the title suggests, the service NI Device Loader is not starting automatically on my machine.
I tried to change it to both "Automatic" and "Automatic (Delayed Start)" startup type in the options, added "Restart the service" for all the failures in the "Recovery" tab, to no avail: after the restart the service goes back to "Manual" startup type and is not started.
A lot of other NI services also change to Manual despite the fact that I set them all to automatic before restart. Here is a screenshot of the services after restart:
I fully reinstalled LabView (by first uninstalling all NI software, deleting C:\Program files\National Instruments and C:\Program files(x86)\National Instruments and C:\Programdata\National Instruments, and deleting all Software\National Instruments in regedit), but still no luck.
I went through all the posts on this forum about "NI Device Loader' not starting but none helped.
I wonder what diagnostic steps I could take to find out what causes the issue.
Thanks iin advance for any pointers!
P.S. I am running LabView 2012. Tried different versions of MAX (currently on 5.5) with the same result.
PPS. This might also be relevant: getting this error with DataFinder not being able to start, though, again, all the posts dealing with this issue did not help:
Message 1 of 9
(10,459 Views)
For the latter one: Your NI PSP Service Locator service should have the startup type "Automatic".
Message 2 of 9
(10,431 Views)
I know... It goes back to Manual after restart, like the rest of NI services in the screenshot... Something else is preventing the automatic start of these services, but what it could be I have no idea...
Thanks!
Message 3 of 9
(10,426 Views)
Hi SensLabs,
Could you check this forum and see if the suggestion given by DianaS helps?
Service NI Device Loader isn't starting automatically - Discussion Forums
http://forums.ni.com/t5/Measure/Service-NI-Device-Loader-isn-t-starting-automatically/m-p/551763
Message 4 of 9
(10,423 Views)
@wfernand wrote:
Hi SensLabs,
Yes, sure, I tried it several times and each time my list of NI services gors back to Manual, as in the screenshot.
Thanks!
Message 5 of 9
(10,409 Views)
From MSDN:
To perform this procedure, you must be a member of the Account Operators group, the Domain Admins group, the Enterprise Admins group, or you must have been delegated the appropriate authority. As a security best practice, consider using Run as to perform this procedure.
http://technet.microsoft.com/en-us/library/cc755249.aspx
(this procedure = configure how a service is started)
Message 6 of 9
(10,395 Views)
@StefanR wrote:
From MSDN:
Well, I am the administrator on this machine, I don't think this is the issue, unless I misunderstood what is meant by this note. If I weren't the admin, Windows wouldn't even let me change the startup type. Instead it lets me do it but then resets it as soon as I restart.
Thanks!
Message 7 of 9
(10,393 Views)
Even you being the admin, you have to chose "run as admin..." to execute the application as admin to change the service start option .....
Message 8 of 9
(10,344 Views)
Yes, I've done this. I also done this running command prompt as an admin and changing the startup type using command line...
Thanks!
Message 9 of 9
(10,341 Views)
