Measure
"NI-MAQ 32-bit Driver support installation has failed"
Dear All,
im need install IMAQ PCI-1407 on win7 32-bit. Every time is installation ended by message "NI-MAQ 32-bit Driver support installation has failed"
im using IMAQ 4_6_4
Thanks for your help
(6,544 Views)
Hi....
Can you attached a MAX report file in this forum? A technical report is enough.
->Open MAX
->File create protocol
Get you only the mesage which you have written or ist there more  information in the error popup?
(6,536 Views)
