Measure
"wavebook 512" continuous measurement
i have a problem with "wavebook 512".
i have to measure voltage continually but wavebook 512 measure it instantaneously. so all the voltage data and waveform vs. interrupted.
comminication between PC and wavebook 512 is easy. using LPT port and there is no problem. i am getting correct measurement data but like i said it is only 5 or 6 period.
measured voltage is 50 Hz.
using labview 8.0 and iotech wavebook driver.
how can i measure 50 or more periods by "wavebook 512" ?
Thanks 🙂
(6,877 Views)
You've posted this to the wrong board. The NI Measure board is for an old add-in for Excel called Measure. You should post to the LabVIEW or Instrument Control board. It would help if you included your VI and the driver.
(6,873 Views)
