Measure
requirement gateway- management view
In the management view is it possible to customize the coverage % display.
Example:
I have 10 requiremets. I have covered for 5 requiremets. Management view says 50% since 5 more uncovered.
But out of 5, there are 2 is non testable requirements.
I have remove 2 non testable requirements for the coverage calculation.
Here actually 62 % is the coverage ratio after removing those 2 non testable requirements.
Is it possible to customize the management view.
Note:  I have attribute applied to those non testable requirements.
How to do that?.
Thanks a lot for your quick reply.
(6,954 Views)
Kals,
Unfortunately, I don't have enough information to help you.
How are you modifying the coverage calculation?  What about the management view would you like to customize?  What are you trying to accomplish?
Josh W.
Certified TestStand Architect
Formerly blue
(6,943 Views)
