Measure
volatage measure
Hi
I Begginer in the Labview programming
I´m trying to make a program in order to measure voltage. but i need to place limits  high and low. if the volatge measure is within the these limits the result wll be opass. otherwise will be fail
I´m currently ussing the device USB 6009
Please
Can anybody help me??'
(6,325 Views)
This board is for the Excel add-on product called 'Measure'. You should have posted to the LabVIEW board.
All you need to do is use the In Range and Coerce function on the Comparison palette.
(6,323 Views)
Hi
First to all sorry for the mistake, since the title should be voltage
Thank you for the suggest
(6,319 Views)
Check out the following link:
http://zone.ni.com/devzone/cda/epd/p/id/4997
It will get you started with NI DAQmx for analog inputs.  Once you get how it works, you can use the "In Range and Coerce" function.  This function allows you to establish the upper and lower limit for the input value, while the output is a boolean that indicates if the value is within the established range or not.
You can find this function under Programming --> Comparison.
Hope this helps!!
Anuar Rojas
Anuar R.
National Instruments México y Latinoamérica
Ingeniería de Aplicaciones
www.ni.com/soporte
(6,299 Views)
Hi Anuar
Thank you for your feed back, I will analize this example.
(6,293 Views)
