ı have a DAQ cart.ı and want to use with visual studio c#. ı have installed the driver and Measurement Studio but ı cant creat a NI DQA Windows Aplication. only NI class library and NI Windows Aplication. How can ı solve this problem
(3,921 Views)
Accepted by topic author omer61
Howdy Omer!
Make sure you install the DAQ driver after installing Measurmenet Studio. The DAQ driver is what installs the DAQ Windows application template.  It won't install that component unless Measurement Studio is already installed.
Barron
Applications Engineering
(3,897 Views)
thansk.
but,
my problem isnt solved yet. my problem is that, when ı intalled  DAQmx driver and  Measurement Studio 2010 some dll file isnt install .this are NationalInstruments.DAQmx.dll,NationalInstruments.DAQmx.msl,NationalInstruments.DAQmx. ı cant find them in the file C:\Program Files\National Instruments\MeasurementStudioVS2010\DotNET\Assemblies\Current
(3,866 Views)
Hi Omer,
When you install the DAQmx driver make sure you select the components relevant to Measurement Studio for installation.  Also, make sure you are installing a recent version of DAQmx.
Barron
(3,838 Views)
