4882.net class library
Where can I find the documentation for the .NET class library?  I printed off pieces of it from the internet a few months ago and I need to revisit some of the specifics but I can't find it.
Buck
(3,489 Views)
Hi Buck,
If you have installed the NI-488.2 driver and included .NET support, then the NI-488.2 documentation will be directly integrated in the Visual Studio Help. To access the NI-488.2 help, select Start
» Programs » National Instruments » NI-488.2 » NI-488.2 .NET Framework 2.0 Help (select the 1.1 help if you don't use 2.0).
Then you can navigate to NI Measurement Studio Help
» NI Measurement Studio .NET Class Library.  From there, you can either traverse the Reference or Using topics.  I would suggest starting with the Using the Measurement Studio .NET Class Libraries section and take a look at the Using the Measurement Studio NI-488.2 .NET Library.
Hope this helps!
Best Regards,
Jonathan N.
(3,483 Views)
