6602 Calibration Procedure with Measurement Studio .Net
I would like to perform the 6602 Calibration Procedure using Measurement Studio for VB .NET 2005 and NI DAQMX. The example code shown in the procedure uses Labview and I believe Traditional NI DAQ. I've attempted to follow the procedure and replace the steps with .Net code but things aren't working like it seems they should. It seems like I can't route signals the way the procedure is saying to. Is there an equivalent procedure that uses Measurement Studio for VB .NET and DAQMX?
Message 1 of 10
(5,607 Views)
Hi TimER,
Unfortunately there is not a DAQmx version of the 6602 Calibration Procedure.  You should be able to replace the Traditional DAQ code with DAQmx calls.  Can you elaborate more on what is not working as expected?
h_baker
Message 2 of 10
(5,575 Views)
What I am stuck on is how to "route the stable 10MHz clock on the PXI-6608 onto the RTSI line 0" per step 3c in setting up the stable clock section.
Message 3 of 10
(5,560 Views)
Did you try using DAQmx Export Signal?
h_baker
Message 4 of 10
(5,534 Views)
You may not have noticed, but in my original post I mentioned that I am using VB 2005 and Measurement Studio for .NET. I can't seem to locate an equivalent method to "Export Signal" in the Measurement Studio library.
Message 5 of 10
(5,517 Views)
Please see the attached image taken from the .NET help as I believe this should clear up any confusion.
h_baker
Message 6 of 10
(5,501 Views)
Thanks I found the method in the help doc. I couldn't find an example on how to use it, so I wrote this code, which gives the exception:
"Measurements: Signal type requested to be exported is not supported for the specified task running on the given device."
Imports NationalInstruments.DAQmx
Public Class frmExportStableClock
Private CounterTask As Task
Private xsig As ExportSignals
Private Sub btnStart_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnStart.Click
CounterTask =
New Task
CounterTask.COChannels.CreatePulseChannelFrequency("/Dev2/Ctr0", _
 "CalCounter", COPulseFrequencyUnits.Hertz, COPulseIdleState.Low, _
 0, 1000, 0.5)
CounterTask.Start()
xsig = CounterTask.ExportSignals
xsig.ExportHardwareSignal(ExportSignal.ReferenceClock10MHz,
"/Dev2/PFI4")
btnStart.Enabled = False
btnStop.Enabled = True
End Sub
Private Sub btnStop_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnStop.Click
CounterTask.Stop()
CounterTask.Dispose()
btnStart.Enabled = True
btnStop.Enabled = False
End Sub
End Class
Any Ideas?
Message Edited by TimER on 10-28-2009 03:09 PM
Message Edited by TimER on 10-28-2009 03:11 PM
Message Edited by TimER on 10-28-2009 03:12 PM
Message 7 of 10
(5,491 Views)
 More detail on the exception is as follows:
Property: NationalInstruments.DAQmx.ExportSignals.ReferenceClock10MHzOutputTerminal
Task Name: _unnamedTask<0>
Status Code: -200375
Message 8 of 10
(5,485 Views)
body { margin: 0 0 0 0; padding:0 0 0 0 } td,div { font-family:Tahoma;font-size:8pt;vertical-align:top } body { margin: 0 0 0 0; padding:0 0 0 0; overflow:hidden; } .transcript { background-color:#d2d2d2; } .messageBlock { margin-left:4px; margin-bottom:3px } .message { margin-left:100px; word-wrap:break-word; white-space:-moz-pre-wrap; _white-space:pre; } .messageCont { margin-left:100px; word-wrap:break-word; white-space:-moz-pre-wrap; _white-space:pre;} .other { overflow:hidden;color:#39577a;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; } .myself { overflow:hidden;color:#da8103;font-style:normal;font-weight:bold;font-style:normal;float:left; width:95px; } .otherCont { font-size:8px;text-align:right; color:#39577a;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; } .myselfCont { font-size:8px;text-align:right; color:#da8103;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; } .system { margin-left:4px; word-wrap:break-word;color:#da8103;font-style:normal;font-weight:normal; white-space:-moz-pre-wrap; _white-space:pre; } .showTimestamp { padding-left:8px; margin-right:3px; float:right; color:#999999;font-style:normal;font-weight:normal; } .other1 { color:#ac2000;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; } .otherCont1 { font-size:8px;text-align:right; color:#ac2000;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; } .other2 { color:#3c9fa8;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; } .otherCont2 { font-size:8px;text-align:right; color:#3c9fa8;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; } .other3 { color:#e25614;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; } .otherCont3 { font-size:8px;text-align:right; color:#e25614;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; } .other4 { color:#0b6ac8;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; } .otherCont4 { font-size:8px;text-align:right; color:#0b6ac8;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; } .other5 { color:#b23290;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; } .otherCont5 { font-size:8px;text-align:right; color:#b23290;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; } .other6 { color:#02e7c7;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; } .otherCont6 { font-size:8px;text-align:right; color:#02e7c7;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; } .other7 { color:#5b3284;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; } .otherCont7 { font-size:8px;text-align:right; color:#5b3284;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; } .highlight { background-color:#bed6f8; } .datestamp { cursor:default; margin-bottom:1px; background-color:#c0c0c0; width:100%; float:left; text-align:right; color:#ffffff; font-weight:bold; font-style:italic; } #chatAlert { float:left; border-bottom:1px solid #E8D091; padding:6px; width:100%; color:#A5754C; } #chatAlertImage { float:left; } #chatAlertText { float:left; margin-left:6px; } #chatAlertClose { float:right; margin-right:10px; padding-right:6px; margin-top:0px; } #chatAlertText a { color:#A5754C; } #chatAlertText a:hover { color:#A5754C; text-decoration:none; } .tsDisplay { display:block }.dsDisplay { display:none }
If you are using an external clock, then you do not need to export signals at all. You need to bring the clock in on a PFI line and use that PFI line as the timebase for the 50 ms pulse you need to generate.
If you are using the clock of the PXI-6608, put the PXI-6608 in Slot 2 of your chassis. The OCXO clock (which is the 10 MHz clock you need to use for calibration) will automatically overwrite the backplane clock. Then use the DAQmx CIChannel.CounterTimebaseSource Property and set it use the PXI_Clk10_In line. body { margin: 0 0 0 0; padding:0 0 0 0 } td,div { font-family:Tahoma;font-size:8pt;vertical-align:top } body { margin: 0 0 0 0; padding:0 0 0 0; overflow:hidden; } .transcript { background-color:#d2d2d2; } .messageBlock { margin-left:4px; margin-bottom:3px } .message { margin-left:100px; word-wrap:break-word; white-space:-moz-pre-wrap; _white-space:pre; } .messageCont { margin-left:100px; word-wrap:break-word; white-space:-moz-pre-wrap; _white-space:pre;} .other { overflow:hidden;color:#39577a;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; } .myself { overflow:hidden;color:#da8103;font-style:normal;font-weight:bold;font-style:normal;float:left; width:95px; } .otherCont { font-size:8px;text-align:right; color:#39577a;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; } .myselfCont { font-size:8px;text-align:right; color:#da8103;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; } .system { margin-left:4px; word-wrap:break-word;color:#da8103;font-style:normal;font-weight:normal; white-space:-moz-pre-wrap; _white-space:pre; } .showTimestamp { padding-left:8px; margin-right:3px; float:right; color:#999999;font-style:normal;font-weight:normal; } .other1 { color:#ac2000;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; } .otherCont1 { font-size:8px;text-align:right; color:#ac2000;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; } .other2 { color:#3c9fa8;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; } .otherCont2 { font-size:8px;text-align:right; color:#3c9fa8;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; } .other3 { color:#e25614;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; } .otherCont3 { font-size:8px;text-align:right; color:#e25614;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; } .other4 { color:#0b6ac8;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; } .otherCont4 { font-size:8px;text-align:right; color:#0b6ac8;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; } .other5 { color:#b23290;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; } .otherCont5 { font-size:8px;text-align:right; color:#b23290;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; } .other6 { color:#02e7c7;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; } .otherCont6 { font-size:8px;text-align:right; color:#02e7c7;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; } .other7 { color:#5b3284;vertical-align:top;font-weight:bold;font-style:normal;float:left; width:95px; } .otherCont7 { font-size:8px;text-align:right; color:#5b3284;font-family:Arial,Lucida Grande;font-style:normal;vertical-align:top;font-weight:bold;float:left; width:95px; } .highlight { background-color:#bed6f8; } .datestamp { cursor:default; margin-bottom:1px; background-color:#c0c0c0; width:100%; float:left; text-align:right; color:#ffffff; font-weight:bold; font-style:italic; } #chatAlert { float:left; border-bottom:1px solid #E8D091; padding:6px; width:100%; color:#A5754C; } #chatAlertImage { float:left; } #chatAlertText { float:left; margin-left:6px; } #chatAlertClose { float:right; margin-right:10px; padding-right:6px; margin-top:0px; } #chatAlertText a { color:#A5754C; } #chatAlertText a:hover { color:#A5754C; text-decoration:none; } .tsDisplay { display:block }.dsDisplay { display:none }
h_baker
Message 9 of 10
(5,444 Views)
Epic fail of an attempt last time- sorry.  I will try again.
If you are using an external clock for the timing source, then you do not need to export the signal at all.  Instead bring the clock in on a PFI line and use that PFI line as the timebase for the 50 ms pulse you need to generate.
h_baker
Message 10 of 10
(5,440 Views)
