ASP.NET , OPC, DataSocket
I'm doing an ASP.NET web site which reads some variables from a local OPC  server and displays the value on a gauge ....
First Question:
One interesting thing is that when developing web sites, the Visual Studio Toolbox does not have a "Data Socket" control..........why ????
Second Question:
Bellow is my code ..... Is this the general accepted way of writing such an application ?????
I just want to check and make sure ...
Partial
Class MyForm
Inherits System.Web.UI.Page
Dim T_DS As NationalInstruments.Net.DataSocket = New NationalInstruments.Net.DataSocket()
Protected Sub AutoRefresh1_Refresh(ByVal sender As Object, ByVal e As NationalInstruments.UI.RefreshEventArgs) Handles AutoRefresh1.Refresh
TG.Value = T1_WS_DS.Data.Value
REM TG Is a gauge control
REM TG is registered in the update items of the autorefresh control
End Sub
Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
T_DS.Url =
"opc://localhost/National Instruments.OPCLookoutDrivers/DL1.T"
T_DS.Connect()
End Sub
End
Class
(4,557 Views)
Hello Sebastian,
It looks like the answer to your first question can be found in this previous discussion.
For your second question, as with all programming languages there are a number of ways to perform most functions.
Specifically in regards to Measurement Studio and Datasockets, I would recommend looking at the Datasocket examples for reader and write that we have provided, this will provide you with one successful implementation of datasockets.
Thanks for posting!
With warm regards,
David D.
(4,531 Views)
