ASP.NET Webform: Autorefresh does not work
I'm developing an ASP.NET webapplication using NI WebControls (e.g. ni:thermometer or ni:led).
While the edit numeric control always is refreshed (with a rate of about 2 seconds in my case) the ni:led control is not working correctly. After starting the page calling the webapplication the control is updated a few times (may be 2 times up to say 10 times) then the control seems to hang. That meens: the color of the led does no more change; but if one hover the mouse over the control (the led) the tooltip shows the correct (changing!!) value.
As startingpoint for my development i used the NI thermometer example and added a few led's.
Can someone tell me, what may be wrong here?
Greeting PeterMichael
(4,176 Views)
Hi PeterMichael,
perhaps you can post a small example, which shows this behaviour.
This is because we can send this to our developers in the USA.
Thanks a lot.
best regards
Dippi
(4,147 Views)
Hi Dippi,
please find additional informations in the attached zip-archive, including:
Default.aspx
Default.aspx.cs
In a three-line table the page displays by <ni:NumericEdit> - controls the return values (temperatures) of different webservices. The LED's should show the result of ping requests to the servers (is server online?). For debugging i replaced the 3-rd servicecall by a flag toggeling every 2 seconds and the led by a thermometer. The result is:
-  the <ni:NumericEdit>-control shows always the correct value
- the <ni:thermometer>-control does not show the toggeling value, however when you hover the control the tooltip shows you the correct value.
  (if you replace the thermometer by a led it shows the same behaviour too)
Hope yu can help me.
best regards Peter
(4,135 Views)
