ASPWebForm:Textbox, NetworkVariables and AutoRefresh
  I have a need to create a web control that contains a text box, this text box should refresh every one second.  In the refresh event the code will return a value of a network variable.  Basically a bound text box with a 1 second refresh interval.  I need to do this only using items fond in Measurement Studio, using AJAX is not an option.  I believe the AutoRefresh timer uses AJAX of sorts and that's fine, just cant' use an UpdatePanel and Timer.
This has to be a text box, not the NumericEdit, the value will need to update but no cause a page post back.
any ideas?
Thanks.
Eric.
(3,769 Views)
Eric,
Since you have already discussed this with several of our support engineers via phone conversations, we will focus our efforts via that line of communication.  I hope that the example that Jett put together for you worked for your application!  Feel free to let us know if you have further questions.
Derrick S.
Product Manager
NI DIAdem
(3,747 Views)
