Alternative for CurveFit.LinearFit in Winforms C#
Hello team,
I am using the Beta version of MS 2019 for VS 2017. Due to the lack of merge module NiAnlys.msm in this beta version. I keep getting DllNotFoundException at the client location for my Visual Studio setup project.
Not quite sure why this merge module is taken off and what is the alternative for this merge module in beta version. Until this issue resolved I would like to know if there is a alternative for the CurveFit.LinvearFit() method in C#
Since CurveFit.LinvearFit() is the only method I am making use from the NationalInstruments.Analysis.Math and  as I have the above issue. I am trying to find how can I not use the NationalInstruments.Analysis.Math and still make use of a CurveFit.LinvearFit().
(2,634 Views)
BabaGoud,
If you have a question about the beta, you should post to the forum specifically for the beta. You should have been given access to that forum in an email when you got the beta. That will be the best place to ask those type of questions.
I am not sure if I have the correct link because I don’t have access, but according to this, it seems that you are looking for this forum page.
Hope this helps!
(2,605 Views)
