Application crash after deploying with measurement studio 9
I have simple application that pull data from a serial port and display several curves on 4 stripchart controls. This application works perfectlly when running visual studio. I build setup project to deploy the application to my customers. After I install this application on a PC it runs about 500 sec and then crashes. How can I diagnosticate the problem?
Cheers
Nikolai
(3,423 Views)
Hello Nikolai
form what you have written in your post it is quite hard to determine what the reason is for the crash.
I guess you deploy the application to another computer not to your Developement System.
I found a Knowledgebase on MSDN explaining how remote Debugging on compiled Visual Studio Executable works:
http://msdn.microsoft.com/en-us/library/bt727f1t(VS.71).aspx
I hope that you can find the cause for the problem with remote Debugging.
My guess would be a missing driver.
Regards
(3,375 Views)
