Are there event handlers for graphic objects drawn with the CWIMAQViewer toolbar?
I use the CWIMAQViewer in my VB.Net  application to display images from a CCD camera.  I want to use the toolbar that comes with the viewer to draw graphics (e.g. a circler) over the image.  Is it possible to get the position and radius  of the circle as I drag it and change its size?  If not, what library should I use (I do have the NI Vision module) to achieve my goal?  Thank you so much for your help.
(4,851 Views)
Have you tried to use any of the overlays?  That's where I'd start if I wanted to draw a circle over a portion of the image.
(4,808 Views)
I can draw a circle overlay over the image with no problem.  My question is: when I move the circle or change its size, is there a way to know its new location and size?
(4,796 Views)
Try creating the circle as a ROI.  Then take a look at ROI properties.  As an example, ROITop Property: CWIMAQ.ROITop
(4,778 Views)
