AxisDouble YRange label presenter format
I was trying to set the AxisDouble label presenter formatted by "0.00". But when the minimum value of Y Range is like 0.00123456, it shows the whole digital string instead of 0.00. This is my xaml, and attached is the plot view. What is missing here please?
<ni:AxisDouble x:Name="yAxis" Label="{Binding GraphYAxisLabel}" Orientation="Vertical" Range="{Binding YRange}" Adjuster="None">
    <ni:AxisDouble.MajorDivisions>
        <ni:RangeLabeledDivisions>
            <ni:RangeLabeledDivisions.LabelPresenter>
                <ni:GeneralValueFormatter Format="0.00" />
            </ni:RangeLabeledDivisions.LabelPresenter>
        </ni:RangeLabeledDivisions>
    </ni:AxisDouble.MajorDivisions>
</ni:AxisDouble>
Xu
(2,516 Views)
Can somebody from NI kindly help on this issue please? Much appreciated.
(2,464 Views)
The formatter internally does work to avoid displaying non-zero values as if they were zero. The formatter will try using both Format and ShortFormat for a non-zero value that displays as zero, so you could specify e.g. ShortFormat="0.00###" to control the number of digits displayed for near-zero values.
~ Paul H
(2,449 Views)
