Browse DAQmx Devices?
I know that it is possible to browse and retrieve information for DAQmx devices within LabVIEW.  However, I would like to do the same within my MS 8.0.1 application.
An example of how this is done in LabVIEW:
Discussion Thread for browsing DAQmx devices in LabVIEW
VI that can retrieve DAQmx information in LabVIEW
Any advice on how to do this in LabVIEW would be appreciated.  Also, are all of the property node classes accesible through Measurement Studio?
Thanks!
CLA, CTA
(6,037 Views)
Hi LVB,
Programmatically retrieving information about DAQmx devices from the DAQmx for .NET API is fairly easy once you know where to look.  The following C# code sample demonstrates this:
foreach (String deviceName in DaqSystem.Local.Devices)
    Device
d = DaqSystem
.Local.LoadDevice(deviceName);
    StringBuilder
s = new StringBuilder
    s.AppendLine(
"DeviceID = "
+ d.DeviceID);
    s.AppendLine(
"Simulated = "
+ d.IsSimulated);
    s.AppendLine(
"Product Category = "
+ d.ProductCategory);
    s.AppendLine(
"Product Number = "
+ d.ProductNumber);
    s.AppendLine(
"Product Type = "
+ d.ProductType);
    s.AppendLine(
"Bus Type = "
+ d.BusType);
    MessageBox
.Show(s.ToString());
Or in VB.NET:
For Each deviceName As String In DaqSystem.Local.Devices
    Dim d As
Device = DaqSystem.Local.LoadDevice(deviceName)
    Dim s As StringBuilder = New
StringBuilder()
    s.AppendLine(
"DeviceID = "
+ d.DeviceID)
    s.AppendLine(
"Simulated = "
+ d.IsSimulated.ToString())
    s.AppendLine(
+ d.ProductCategory.ToString())
    s.AppendLine(
"Product Number = "
+ d.ProductNumber.ToString())
    s.AppendLine(
"Product Type = "
+ d.ProductType)
    s.AppendLine(
"Bus Type = "
+ d.BusType.ToString())
    MessageBox.Show(s.ToString())
This example will display a message box giving information on each device present on your system.  I believe this should answer your question.
Hexar Anderson
Measurement Studio Staff Software Engineer
(6,017 Views)
Is there any way to read Compact FieldPoint device configurations from a VB.NET application?
I'd like to be able to dynamically load the available channels and their names to be used in a test configuration management application.
(5,903 Views)
webcmc,
When you say that you will be using this as a test system, do you always expect to have the same modules in the different cFP chassis? I know it is possible to use the .NET class library to communicate with I/O points on your FieldPoint bank (Communicating with FP modules with VB .NET). I also know that you can obtain a channel listing in LabVIEW (Accessing available FieldPoint I/O points) but I am not certain if this functionality exists for VB.NET. I will do some digging into this API to determine if this is possible. Please post back to this forum if you have any further insight into this capability. Thanks,
-Mike
(5,871 Views)
I would also like to know if it's possible in MS 8.0.1 to retrieve information from a compact fieldpoint device (cfp-1808).
(5,607 Views)
Hi Crusader,
The best way to communicate with your compactFieldPoint devices is through an OPC server. An OPC server is installed automatically when you install the cFP drivers. Take a look at the following documents and examples, which will explain further:
Can I Use Microsoft Visual C++ 6.0 and/or Visual C++ .NET with My FieldPoint Modules?
Reading Data from an OPC Server using DataSocket in Visual Basic
Creating a DataSocket Reader/Writer with Measurement Studio ActiveX Controls in Visual C#
Developing Industrial Automation Applications using Visual Basic .NET and OPC
Developing an OPC Client Application Using Visual Basic
Cheers.
Michael K.
| Michael K | Project Manager | LabVIEW R&D | National Instruments |
(5,590 Views)
